clutch pushrod question
keefer
Tue Apr 15, 2008 5:12 pm » Post: #1 » Download Post
hello i have been looking at getting a new clutch cable for my MC28 as i have had to wind it right out to make it work.
but on striping out the plates to clean them off it appears i could be missing a part?
is there meant to be a small ball bearing situated on the end of the push rod. just before the hub that mounts into the outer plate (god that makes sense) hopefully those who have taken it apart recently will know what i am on about.
Many thanks. K
SPENGILLY
Wed Apr 16, 2008 2:32 am » Post: #2 » Download Post
Did you check the parts manual? It will show all the parts on the clutch.
cgallant
2001 Honda RS250
Wed Apr 16, 2008 4:20 pm » Post: #3 » Download Post
to answer your question, yes there is a steel ball between the push rod and the lifter part.
Charles Gallant
Wed Apr 16, 2008 8:10 pm » Post: #4 » Download Post
And this steel ball (part #96211-10000, it's just a 5/16" ball bearing really) has the ability to both roll several yards over an uneven floor or vanish from sight at will.
keefer
Wed Apr 16, 2008 9:38 pm » Post: #5 » Download Post
mine has done the vanishing trick.
been a long time since i have had the bike out or worked on it. could see there was something there on the parts list just wanted to make sure.
fingers crossed i should be back on the road next week Smile
hope there is some sunshine
