PGM3 Ignition Timing
Deon
1990 Honda NSR250 MC21
Fri May 02, 2008 6:47 am » Post: #1 » Download Post
I'm running a pgm3 with no gps on the engine. The green-red wire is earthed and the rest are not connected. What ignition timing will this give me.
Deon
Fri May 02, 2008 4:32 pm » Post: #2 » Download Post
Never mind. On closer inspection it turned out to be the green-brown wire. Second gear ignition timing.
Sat May 03, 2008 3:36 pm » Post: #3 » Download Post
Second isa bit radical. Mind it doesn't go bang in top...
Deon
Sat May 03, 2008 4:44 pm » Post: #4 » Download Post
it should be cool. it's only a short circuit racer (110kph or so). a switch on the bars between 2nd and 3rd will be good (I think???)
Sat May 03, 2008 7:38 pm » Post: #5 » Download Post
Probably, but perhaps a bit overkill. The wre splice uses first, second and third as usual, but then stays with third for fourth, fifth and sixth.
