Hi,
With all this talk on rebuilding cranks and sourcing center bearings from various places Im hoping someone will be able to shed some light on a crank I have here...
This crank has been rebuilt - the bearings are not original Honda items. The center bearing is narrower than a standard bearing, it doesnt have provision for the seal, it doesnt have the oil gallery opening - none of them have the locating pin.
Is this what the replacement bearings you guys are using like?
The problem is the center bearing - having no seal may mean the engine wont run properly - this seal keeps the pressure in the two crank halves separate. Also with no provision for the oil gallery Im not sure if it will run dry?
Any thoughts?
