I've just got my MC21 NSR up and running and took it out for a good blast yesterday.
It had a bit of a splutter in the mid range but once it got into the peak revs it was good as gold .
I was just having a look throught the tech section to see if I have set everything up right and came across the power vet breather diagram.
On my one there is the Y section that splits of and it has a 90* 3 way joint put I can't see what the nipple that comes off it should plug into...any idea???
Can you post a photo of the part you are concerned about? It sounds like the 3-way joint that should normally plug into a little filter pressed into the bottom of the airbox. Is the joint white? _________________ Andy.
Answers won't always be immediate, but somewhere along the line most things have been covered by someone here, and people will share their knowledge. Always try a search though, because if the info is easily accessible you'll soon know about it! _________________ Andy.
