Now i know this has probably been asked before but how should the servo motor for the power valve operate. Just following the setup procedure for the power valves and my servo seems to rotate high to low and then back to the middle or just random when just blipping the throttle but when you wind it on as if accelerating it moves from low to high? Is this normal?? _________________ MC21 300
Aprilia RS250 track bike
excuse me, my friend, where can i find the setup procedure for the rc valve? i'm just finishing rebuilding a MC16, i have repaired some of the gears of the servo but now i don't know how to set it up and i'm afraid to make some catastrophe, as i read here, if i set it up wrong. the resistance measures right values and i've tried the servo and it seems to work fine. just seems to, because i don't know how does it move when working right. thanks in advance.
m.
