Common problem?
End Can
Common problem?
Wed Nov 17, 2004 9:56 pm » Post: #1 » Download Post
my right hand side bearing gave up can't get the bearing to fix it went to a crank rebuilder he had another five cranks from nsr's with the same problem.
Can i use an rgv crank? where can i get the bearings from for my 87 nsr/sp.
Saw a complete mc16 engine for sale but it's down on compresion compared to my nsr can i put my barrels and heads on the mc16 engine to regain the sp power.
if so is the timing the same in the pgm box?
i'am a bit down at the moment my nsr was a rocket until it went bang it only had 18k on the clock.
jeff350lc
Wed Nov 17, 2004 11:13 pm » Post: #2 » Download Post
you can use the mc16 motor but if you have an sp you will loose the dry clutch . use your original carbs pgm etc and you will have almost the same power. for crank bearings click on the link on the home page.
