question about oil
Bigwave
question about oil
Thu Aug 14, 2008 6:52 am » Post: #1 » Download Post
I searched around a bit but could not find an answer.
What engine oil do you all use in your 250s?
I just picked up a 91 MC21 and want to take care of it.
thanks.
dave
Thu Aug 14, 2008 11:34 am » Post: #2 » Download Post
Castrol TTS in mine.
banshee
1996 Honda NSR250MC28SE
Thu Aug 14, 2008 12:07 pm » Post: #3 » Download Post
motul 710 ( 2 stroke )
10w 40 gearbox oil ( fully syn )
jeff350lc
Thu Aug 14, 2008 1:45 pm » Post: #4 » Download Post
banshee wrote:motul 710 ( 2 stroke )
You don't want to use fully syn engine oil with a wet clutch though.
As for the engine Motul or Rock for me. (fully syn)
Ran rock oil in a 330 Gas Gas trials side car outfit, that bike was used from club up to British championship trials, and in three years all it ever had was a ring. That engine was tuned and used hard I can tell you. Twisted Evil
Bigwave
Thu Aug 14, 2008 5:19 pm » Post: #5 » Download Post
Excellent, so 10w40 engine weight is good. synthetic is prefered.
This is a street bike not a full track bike so it wont see to much abuse, ok maybe not as much riding around a track without police.
JohnBlaze
    Send private message View user's profile Visit poster's website AIM Address
Thu Aug 14, 2008 7:43 pm » Post: #6 » Download Post
[quote]Excellent, so 10w40 engine weight is good. synthetic is prefered.
[/quote]
NOOOOOOO! Please tell me your not going to put that in the engine! Only 2t oil goes in the motor. Do you have an injector setup or is it premix? I notice your in San Diego...Me too. Where abouts do you stay?
MC21 300R w/SE bits, Rossi 2001
MC28SE Silhouette Repsol
Thu Aug 14, 2008 7:56 pm » Post: #7 » Download Post
What?
Actual Honda spec for the gear oil is 10W-30 gear oil (shocking that eh?) but 10w-40 (as long as it's not got slippy car agents in it) is OK.
Bloody 2 stroke oil is NOT!
I fail to see the relevence of injector or pre-mix.
Styler_Colfax
Thu Aug 14, 2008 8:17 pm » Post: #8 » Download Post
I use Repsol 10w-40 in my dry clutch gear box and Castrol A747 for my premix
1993 MC21 SP
Bigwave
Thu Aug 14, 2008 8:35 pm » Post: #9 » Download Post
I'm in Point loma... when I get this thing tiptop lets go to palomar mt.
sorry but what is 2t oil? is that the 2 stroke for premix/direct injection.?
I have direct injection...
banshee
Thu Aug 14, 2008 8:39 pm » Post: #10 » Download Post
how about this
any fully synthetic 2 stroke ( either premix or injector )
10w 30 or 10w 40 fully synthetic for the gearbox ( dry clutch )
10w 30 4t or 10w 40 4t fully synthetic ( wet clutch )
RichG
Fri Aug 15, 2008 7:49 am » Post: #11 » Download Post
Dave (bigwave), you should read this http://www.nsr-world.com/rockoil/
You need a 100% fully synthetic 2 Stroke (2T) oil for the engine, delivered by oil injector in your case (rather than premixing with fuel in tank). The top spec fully synthetic 2T injector oils from leading lube manufacturers such as Castrol, Rock Oil, Fuchs Silkolene, Motul, Shell etc is what you need.
Make sure you don't use synthetic 2T scooter oil or semi synthetic 2T oils.
2 stroke engines are completely separated from the transmission, with respect to oil. Unlike 4 stroke engines where the oil has to lubricate the engine & gearbox. So choose a dedicated 2 Stroke Motorcycle Gear Oil, again from one of the manufacturers above (or equivalent).
Wet or Dry clutch? Some racing 2T gear oils, designed for bikes with dry clutches, have enhanced high shear lubricating film additives (reduced friction under high load). As the gearbox oil does not touch the clutch, this is good. But if the clutch is Wet, the gearbox oil also lubricates the clutch plates. Such 'special race' gear oils can actually reduce friction so much they can cause the wet clutch plates to slip. To make it easy, most leading lube manufacturers make high end 'universal' motorcyle gearbox oils which are suitable for both wet & dry clutches.
Don't mess around looking for a 4 Stroke (4T) synthetic engine oil for your NSR gearbox.
Rich
maxim
Fri Aug 15, 2008 4:15 pm » Post: #12 » Download Post
I've used Shell Light Gear Oil in every 2 stroke I've owned with no probs.
Bigwave
Mon Aug 18, 2008 6:33 pm » Post: #13 » Download Post
Thanks to all of you guys for your time and information...
I have a good idea now on what to use.
fully synthetic. It looks like brand wont have a large impact as long as I use the correct weight, and that seems to be 10w40 for the gear box.
Thanks
Dave
EDIT - just so your guys know, I have the wet clutch I think as its just the nsr 250R not the sp or se models, and its oil injected.
