Water leak
brentz250
Water leak
Sat Jul 10, 2010 7:54 pm » Post: #1 » Download Post
Hi
Just installed my rebuilt engine in my MC21 and i have got water leaks from two head studs on the top cylinder and 1 from the head stud on the bottom barrel.
Any suggestions as to what might be causing it
thanks
Sat Jul 10, 2010 8:13 pm » Post: #2 » Download Post
A leaking gasket?
Take the heads off and make sure the cylinders aren't cracked around the studs.
brentz250
Sat Jul 10, 2010 8:18 pm » Post: #3 » Download Post
Thanks
If the cylinders are cracked around the studs is there anything that can be done - apart from new cylinders.
Thanks
Sat Jul 10, 2010 10:01 pm » Post: #4 » Download Post
I have had them welded before but its not very pretty.
Best get the heads off and have a look. It normally happens when the studs have been reinstalled and over tightened.
