Primary Gear Removal
montsta56
Wed Sep 17, 2008 7:14 am » Post: #1 » Download Post
Hi Guy's
Any tips on removing the primary gear off the crank when doing a bottom end rebuild, Gear Puller maybe ??, Also any advice for fitting primary gear onto the new crank.
Anthony
geckoracing1
1996 Honda NSR250 MC28
Tool
Wed Sep 17, 2008 5:42 pm » Post: #2 » Download Post
Anthony
There are a number of tools you can use. The easiest one to make, is a thick brass plate with a slot cut down the middle. A thin U shape. You slide this under the little end of the conrod (with piston removed). It needs to be long enough to bridge the gap in crankcases and sit flat on the base gasket both sides. This stops the crank from spinning when you turn the bolt on the end of the crank. This works whether you undo it or tighten. The use of brass prevents damage to conrod.
The cheap way is to get a thick sturdy piece of cloth and feed it between the two gears on the crank and back of clutch. This jams the gears and stops everting spinning and you can undo or tighten the bolt.
Dan
Wed Sep 17, 2008 7:15 pm » Post: #3 » Download Post
Proper tools on a two stroke is cheating! Wink
montsta56
Wed Sep 17, 2008 11:37 pm » Post: #4 » Download Post
Cheers for that guy's,
I have the nut off but cant seem to get gear off the end of the crank. Would heating it slightly help?
Thu Sep 18, 2008 2:46 am » Post: #5 » Download Post
Absolutely not! Under no circumstances whatsoever should it be heated, levered, or hit with anything.
Use a puller.
Thu Sep 18, 2008 9:26 am » Post: #6 » Download Post
Unless you never want to use it or the crank again... Wink
