21SP Dry Clutch into a 18 R2J?
hutch
Sun Jan 04, 2009 8:06 pm » Post: #1 » Download Post
Is this conversion workable or are the engines too unlike??
Sun Jan 04, 2009 8:18 pm » Post: #2 » Download Post
It's quite an easy swap. You will need the SP/SE gear box and to be safe the crank primary gear though.
I did the same on my R5K.
hutch
Sun Jan 04, 2009 9:05 pm » Post: #3 » Download Post
Thanks Stephen, i'll need to probably source a crank primary gear which might be a balls ache
Sun Jan 04, 2009 9:19 pm » Post: #4 » Download Post
I might have a SP one here if you can't find one. The clutch gear should fit but the last two I've swaped needed a new primary gear.
hutch
Sun Jan 04, 2009 9:58 pm » Post: #5 » Download Post
Thanks again Stephen, just waiting to see what exactely is coming with the clutch and if need be i'll give you a shout. Thanks again
Sun Jan 04, 2009 10:02 pm » Post: #6 » Download Post
Try fitting it first, if the clutch gear goes on with the primary gear fitted then there is no need to get one.
