I might have a SP one here if you can't find one. The clutch gear should fit but the last two I've swaped needed a new primary gear. _________________ If I have to take the carbs off once more...
Try fitting it first, if the clutch gear goes on with the primary gear fitted then there is no need to get one. _________________ If I have to take the carbs off once more...
