Hi People
I'm struggling with the fitting of my HRC jet Kit. Mainly the replacing of the needles as there so different to the 21's im use to. I've got it to the stage of getting the slide/needle removed but cant get my head around getting the needle out.
thanks
The needle is held in with a little white clip. You need a very thin phillips screw driver. A quarter of a turn anti-clockwise and alittle pressure should release the plastic clip and then allow the needle to be removed. The white plastic clip is retained on top of the needle by a spring. _________________ If I have to take the carbs off once more...
Cheers Stephen
is the white clip your refering to the star shaped piece you can see on top of the Slide with what looks like a Hex key Pattern in the middle??
THanks Glad to have you back.
Anthony
Yes thats it, press lightly down on it while you turn it anti clockwise. You'll feel it release. You can then just push the needle up with the clip retained on top. _________________ If I have to take the carbs off once more...
it's only the carbs that are 28..... thank god.
The rest is pure 21
Another thing when putting in the new needles do i retain the washer that was under the standard needle??
I can only assume you could only find an MC28 HRC kit and not an MC21 kit? No sane person would fit MC28 parts to a 21, surely?! _________________ Andy.
Yet Another Question, Ont the base setting guide for 28 carbs for the needles it state's
JN - j8yb 2.765-3.0~4.0 WTF
My needles say things like A25 a/b/c
can anyone help me with this,
an also do I count the clip position from the top or bottom.
Thank you guy's
Not that I could be of any help, but the 3rd clip position (middle) works out to be just under 4mm from the clip to the top of the needle. Just a guess.
So I Should be using the B Needle's as per base setting an wat clip??
Or should I just use the standard ones for the minute till it get's a spin on the dyno??
