mc18 - 21 parts interchange
paul
Sat Nov 27, 2004 10:17 pm » Post: #1 » Download Post
i'm looking at buying a mc18 for parts , will the motor fit into a mc21 frame?
jeff350lc
Sun Nov 28, 2004 3:47 pm » Post: #2 » Download Post
the engine will fit no problem at all.
paul
Mon Nov 29, 2004 3:08 am » Post: #3 » Download Post
thanks
Very Happy
salopbike
1989 Honda NSR250 MC18
Mon Nov 29, 2004 10:14 am » Post: #4 » Download Post
apart from minor changes, pgm etc is the 18 and 21 engine the same?
"cant you see the no smoking sign, this is a public space" rrrrrrriiiiinnnnngggggg ddddddiiiiinnnnnnggggggg 2 stroke till i die
Mon Nov 29, 2004 4:04 pm » Post: #5 » Download Post
Yeah, the MC18 and MC21 motors are identical... except the cranks, the barrels, the heads, the ignition, the left crankcase, and the inlet... apart from that, it's pretty much the same!! Wink Oh, there are some other bits too, but...
Seriously though, the motor will bolt straight in, and run perfectly fine with the different crank/barrels etc., but you will need to use the MC21 stator and flywheel, and look into what you want to do with the G.P.S. as the MC18 doesn't have one!
NOTE: Cranks are NOT interchangeable between MC16/MC18/MC21.
