spark plugs
jeff350lc
spark plugs
Fri Dec 10, 2004 11:53 am » Post: #1 » Download Post
i,m running the standard NGK BR9ECS plugs in my mc16. should i change to a cooler running plug for track days dyno runs etc.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Fri Dec 10, 2004 2:46 pm » Post: #2 » Download Post
The BR9ECS are very slightly different to the BR9ECM (fitted to MC18 on), but should be fine provided that there's been no other mods to the bike.
You could change to a #10 plug whcih would be more effective at high rpm and higher combustion temps, but may foul at lower rpm.
jeff350lc
Sun Dec 12, 2004 8:31 am » Post: #3 » Download Post
thanks matt. Very Happy
the bike has a drilled air box jetted carbs and race pipes. and with luck, will be getting mc21 carbs and some ignition work .
should i use a 10 ECS or ECM ?
maxim
Sun Dec 12, 2004 11:03 am » Post: #4 » Download Post
I've got a set of 21 carbs if you haven't got some already...
SFSR
Sun Dec 12, 2004 10:43 pm » Post: #5 » Download Post
maxim wrote:I've got a set of 21 carbs if you haven't got some already...
Bl**dy hell Mc21 carbs are springing up everywhere Shocked
sfsr
one MC16 almost complete and.....
jeff350lc
Mon Dec 13, 2004 11:54 am » Post: #6 » Download Post
thanks for the offer maxim. i have some carbs sorted.
mc21 carbs anyone Very Happy
