idle screw
john
Guest
idle screw
Fri Dec 03, 2004 2:01 am » Post: #1 » Download Post
On the 92 mc21, how do you adjust the idle screw? It is clockwise to increase the idle or anti-clockwise? What should the idle be at?
thanks.
john
Fri Dec 03, 2004 10:44 am » Post: #2 » Download Post
The idle is listed on the MC21 Specs page. 1200rpm +/- 100rpm.
Turn the idle adjuster clockwise to increase the engine speed.
If the air screws are incorrectly set, or the carbs poorly synchronised, then the idle may not respond very well!
