This past weekend was my NSR's run in and shake down test. I put in "run in" jets and will be putting her on the Dyno this week hopefully.
Everything went well but I noticed that at low rpm, idle, the front cylinder doesn't seem to spark properly.
Once you get the revs up a little more it fires perfect. Could that be spark plug related or possible fouling due to running bigger jets for run in?
