MC18 expires at Anglesey!
MancMC18
Mon Mar 23, 2009 10:59 pm » Post: #1 » Download Post
Oh well, I have been joking about the MC18 blowing up and it did! Previous posts had identified my powervalves as possibly not working at high revs, from 9k upwards - going well at Anglesey on Friday, but had a word with a bloke on an RS250. Advice was to blank off two unattached air lines to carbs (these were undone when bought) and leave powervalve servo on "hi" by undoing green wire to isolate unit (servo was not activating when ignition turned on - I still do not know if it is supposed to cycle on start up!).
Two laps later it seized solid coming out of the fastest right hander onto the main straight. Very embarasing as red flag already out - so they could pick up a knee slider! I went over the highside onto by bonce, taking the fairing with me (only just fibreglassed it together) and sliding 25 yards on my arse.
The upshot is: has anyone got both barrels and pistons for an MC18 (one seized, the other fractured when the pipe hit the deck) or a complete engine? I was just starting to get into it....the Alpha 10s were brilliant but I've only done 20km on 'em. It would also be handy to know which bit of the stupid powervalve balls up was most to blame. Embarassed
I'm also on the lookout for a front fairing (again) and all the right hand throttle, brake, kill switch bits.
More nights in the shed then...
DifferentStrokes
Mon Mar 23, 2009 11:29 pm » Post: #2 » Download Post
o o
Last edited by DifferentStrokes on Mon Sep 28, 2009 9:23 pm; edited 1 time in total
2Smoke
1987 Honda NSR250 MC16
Mon Mar 23, 2009 11:54 pm » Post: #3 » Download Post
Shocked Lesson learnt not to take advice from rs250 riders Laughing
I think the unattached air lines are breathers for the carbs? Had a similar problem on mine when I blocked them up, maybe you've caused it to run hellishly lean thus seizing it! What a pain, wish I'd come down for a look now!
Glad your ok though, you doing the one on the 8th of may?
Paul
Canuck13
Tue Mar 24, 2009 12:04 am » Post: #4 » Download Post
i've a NOS 18 barrel and a couple of used 18 barrels and pistons that are surplus to my requirements. Also a new condition front upper fairing. Only problem is they are in australia. PM if your interested.
Cheers,
Tue Mar 24, 2009 12:04 am » Post: #5 » Download Post
you cant beat a good old highside,i have one on video of me putting my head threw the screen of my rs on my way over the bars Laughing at least your ok mate and by chance was speaking to one of my mates today that highsided his cbr 600rr
cgallant
2001 Honda RS250
Tue Mar 24, 2009 12:08 am » Post: #6 » Download Post
Are your pipes stock? Do they bolt to the cylinders? If so, another good reason to get the quick attach connect with spring type pipes. If your pipes hit the ground, any movement wont cause them to damage the cylinder cause the are solid mounted.
Charles Gallant
