cdi
west
    Send private message View user's profile Send e-mail Yahoo Messenger
cdi
Fri Mar 20, 2009 3:11 pm » Post: #1 » Download Post
when revving the bike, rc vavle opens and closes as its revving up, isnt it supposed to open when revving up and close when the revs go down.
and cant get the bike to idle at the proper rev, its either too high or too low.
Just Bought MC16.
cgallant
2001 Honda RS250
Fri Mar 20, 2009 3:16 pm » Post: #2 » Download Post
The RC Valves do open/close depending on the RPM of the engine, so they should be working fine.
As for the idle, you can check out the workshop area for information on setting up your carbs.
Charles Gallant
DifferentStrokes
Fri Mar 20, 2009 4:46 pm » Post: #3 » Download Post
o o
Last edited by DifferentStrokes on Mon Sep 28, 2009 9:33 pm; edited 1 time in total
maxim
Fri Mar 20, 2009 5:11 pm » Post: #4 » Download Post
I think a standard bike sits somewhere between 1150-1250rpm normally. Should be fine like that.
Fri Mar 20, 2009 5:30 pm » Post: #5 » Download Post
You often find that if the idle is set too high the RC Valve will open, and that can then cause the revs hang. The RC Valve opens at low RPM briefly to aid in setting them up.
Another reason the RPM can hang is because of an air leak or because of carb inbalance.
The "normal" idle does often appear too low, and it does seem like the bike will cut out at any moment, but so long as the carbs are tuned properly*, there's no reason why it should.
*PJ38's (like Maxim's) can be an exception, as they have no idle circuit. They can be fooled into idling though!
DifferentStrokes
Sat Mar 21, 2009 2:37 am » Post: #6 » Download Post
o o
maxim
Sat Mar 21, 2009 9:04 am » Post: #7 » Download Post
I've got PWK39's Andy! Wink Which have a nice little idle circuit. Mine has to idle at around 1650-1700 though to not bog. It runs fine like this.
Sat Mar 21, 2009 11:50 am » Post: #8 » Download Post
Sorry, I thought you had PJ38's. You did have PJ's didn't you, or am I going mad? Confused
maxim
Sun Mar 22, 2009 3:18 pm » Post: #9 » Download Post
No you're not going mad. Still got them too.
