Leaky Fuel Tap
Socket
Leaky Fuel Tap
Mon Mar 30, 2009 5:09 pm » Post: #1 » Download Post
The fuel tap on my MC16 is leaking.
Ive done some rooting through the forum and see that an early CBR900RR fuel tap should fit.
My question is; does anyone know if the repair kit for the 900 could be used to fix the tap on the NSR?
dunkenb
1989 Honda NSR250 MC18
Mon Mar 30, 2009 5:42 pm » Post: #2 » Download Post
on mine i just drilled out the rivets that hold the tap together, took it apart and replaced the rubber o ring with one from a halfrauds multi pak and then just replaced the rivets with a couple of small bolts/nuts.
Socket
Mon Mar 30, 2009 7:55 pm » Post: #3 » Download Post
I did wonder if something like that was possible...but obviously I didnt want to do anything drastic right away because at least the tap kind of works just now! Wink
