The original headlamp bulb is a 35/60w, i've seen information that people have replaced them with the more modern 55/60w h4, how does this work out for those that have tried?
more over, what about replacing it with an HID and ballast? _________________ MC28 sp
H4 bulbs work fine for me - I haven't run into any heat issues or wires melting if that's what you are asking
You will need a H4 bulb converter and have to remove some of the tabs on the bulb to get it to fit.
I was also curious about the HID route, and while they may work/fit, getting the bulb to aim properly in the stock headlamp housing could make your night time driving unsafe. Also getting a "good" HID kit is like buying chinese ABS fairings, kind of a crapshoot
yeah i've got an older mcCullouch 4500k hid kit (ballest, d2r bulb rebased in a h4, and ignitor i had in my 600rr, i was thinking of putting that in. but i'd need to think of a way to make the high beam switch only trigger the H4 (55/60) for high beam. _________________ MC28 sp
Be careful here, general opinion on 400greybike is that much of the trouble with all grey import Honda's blowing reg/recs is cause by running with 55w headlights turned on all the time. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
