Well, as i suspected not a lot going on, little drizzle here and there, usually after a blip
what prompted me to check/disassemble, is 2 reasons,
-because after a cruise the other night, i hopped off, gave her a few blips, and couldn't see any smoke at all, smelled like a car, no oil scent etc and,
-ive filled oil tank once, and refueled 4 times full to empty, and theres still atleast 600ml + in the tank...
Ok so that means its using/pumping ok but, im curious to know weather it pumps stronger when the oil tank is full compared to 1/2 empty
im not sure what can be done short of replacing the pump, as always have done some research thru previous posts. some say its not meant to pump while idling etc..
