Am I the only person that has found it just about impossible to fit the pipes on my bike after a 300 kit install? Mainly the problem is with the upper cylinder's pipe. The angle of the manifold seems to be just a touch off. It puts the pipe right against the lower cylinder, and in it's best position to get the end can in the right spot, the manifold doesn't even come close to sealing against the cylinder......
Need some serious help, I'd hate to try and modify the manifold and make it worse. Hopefully one of you have had the same trouble and can give me the answer.
Thanks, Steve
MC21
04 NSR50R
93 CBR F2
98 CBR F3 track bike
95 VFR750
89 FL400R Pilot
90 FZR 4/600
