Hi, I'm busy fitting an mc21 swingarm into my mc16 so I can run a sensible set of pipes in it, but have come across a small problem that the ride height is now ridiculous, thinking because the swingarm - linkage mount is higher up on the '21's arm.
Has anyone done this conversion before, and if so how was this problem solved? I guess new linkage plates will be the order of the day, unless '21 items bolt straight on and do the job?
And so it goes on....
