Difference of R and SE cylinder
RVT2002
Sat Jun 27, 2009 9:40 pm » Post: #1 » Download Post
Is there a difference between R and SE cylinder? I might be able to buy an R cylinder and put it on my SE engine Smile
Middo
Sun Jun 28, 2009 12:46 am » Post: #2 » Download Post
Search, and ye shall find.....
Basically the difference is in the height of the cylinders, by 0.2mm. You will need to use matching heads, unless you want to start messing around with squish and compression. There are plenty of threads that cover this topic.
RVT2002
Sun Jun 28, 2009 4:05 am » Post: #3 » Download Post
Damn ill just replate my my cylinder then Sad
Sun Jun 28, 2009 7:57 am » Post: #4 » Download Post
Measure it before and after and you'll find they've removed some from the height anyway and more often than not they've took off more than 0.2mm Wink
You can get HRC gaskets in .4 and .6 (and the stock .5 one) to vary the squish. You've got to measure it really unless you know the barrels and heads are totally standard.
RVT2002
Sun Jun 28, 2009 9:28 am » Post: #5 » Download Post
Ok will see if i can make the deal if not got no choice to replate my cylinder.
