Iīm experiencing a strange brake fault:
Front brakes;
Low brake power, get worse at late evenigs.
Have tried to screw the setting but the result is still bad.
A little oil on the discs was discovered and I did clean them but
the brakes is still bad.
Rear brakes; Low to no brake power, setting doesīnt matter,
Installed HRC rearbrake reservoir and new brakefluid.
When I push the brake caliper back the amount of oil in the reservoir
increase but when the caliper returns the brakefluid stays in the reservoir.
No oil leaks.
Edit: the bike has been standing still a couple of years.
Does anyone know what can be wrong?
Happy for a answer!
