I want to get my lower fairing back on my NSR300 so it doesn't look like I'm riding around on some sort of hodge podge two stroke bitzer.
So, is it possible to get the stock fairing to fit my MC21 with 300 barrels and TYGA two up the one side pipes? Will this just require just a bit of bending of brackets etc. or will I have to get the fairing cut? eek.
Btw, I know something will have to be done with the front spark plug, but apart from that... _________________ MC21 Honda NSR250. TYGA 300 conversion.
You should be able to get them to fit as with the off set manifolds that come with the 300 kit they can made to clear almost everything.
As you say the front plug is also abit of a bugger and will require a bit of cutting if youre using the stock BR9ECM plug. _________________ If I have to take the carbs off once more...
