Dry clutch is complete with outer casing too.
Can be delivered as a complete unit by sea cargo , estimated cost to Manchester : £40 ( This will be billed in Yen)
You can either pick up from there or have it sent on by post or courier at your cost.
50,000 Yen engine only payment as gift.
Shipping fee to be confirmed and paid for later. You will also have a small port fee on arrival , expect that to be £10.
Need a quick answer on this so it can go in with the imminent cargo leaving my flat.
Otherwise it will be broken down for it's parts.
I will give a start up warranty ie. the engine will start and run. (Same as any breaker yard would give you) If the engine requires parts within the 1st 3 months of use I will supply said parts at absolute cost if available.
Please leave a dib here.
MM!
Resistance is futile!
