Ok so I have my bike back together. This is my first mc28. during stripdown i removed a second kill switch that had been added to totally disconnect the battery like a battery switch.
Now i have the problem of the bike staying on, well the lcd carries on displaying stuff when the card is removed. I guess this is not correct, so the question is has anyone else had this problem, and how do you fix it? The second kill switch was used to fix the problem by simply cutting off the battery but i dont want this. If the battery is disconnected then reconnected the LCD does not display anything but then if the card is incerted and removed the LCD stays lit.
Another thing to note is up by the PGM some wires have been cut and reconnected but look to be in original order.
94 mc28 SE
