will the mc 21 gull fit into the mc 18 frame? has any one tried yet or am i pissing in the wind? _________________ "cant you see the no smoking sign, this is a public space" rrrrrrriiiiinnnnngggggg ddddddiiiiinnnnnnggggggg 2 stroke till i die
The Gull-Arm will fit the MC18 fairly easily. You will need to make new linkage plates to account for the different geometry, especially if you use the MC18's 18" wheel. You may find the swing-arm pivot on the Gull-Arm is slightly larger than the MC18 (can't remember off hand) so the holes in the frame may need reaming out a little.
It's a much easier job than fitting a Pro-Arm, that's for sure!
update
just got an mc21 gull arm and back wheel on e-bay for £31 so i will put it in and let ya know how easy it is to do _________________ "cant you see the no smoking sign, this is a public space" rrrrrrriiiiinnnnngggggg ddddddiiiiinnnnnnggggggg 2 stroke till i die
will do andy, and be proud to contribute to such a good site _________________ "cant you see the no smoking sign, this is a public space" rrrrrrriiiiinnnnngggggg ddddddiiiiinnnnnnggggggg 2 stroke till i die
can any one help with a caliper carrier and swinging arm spindle for the gull swap, ive posted on the classifieds too _________________ "cant you see the no smoking sign, this is a public space" rrrrrrriiiiinnnnngggggg ddddddiiiiinnnnnnggggggg 2 stroke till i die
