I imagine that would be a bit of a job on an MC28, as it uses a completely different setup to the other NSR's. I expect you will need to have a new "rocker" CNC'd up, but you will have to be very careful not to alter the geometry too much.
I'd try a PM to Matt@TYGA. He may be able to knock something up for you in SolidWorks and make it on his CNC machine, but don't expect it to be cheap! It will probably only be about 1/3 of the cost of a new shock with adjustable ride height though! _________________ Andy.
Never thought of that... never thought there was much wrong with the OEM position! OEM ride height on the other hand, can certainly be improved with a few mm extra. _________________ Andy.
Yeah, because I didn't want to put them on the Racer when it was becomming apparent that no-one else but us was putting anything into it... as it happened, the chassis disappeared along with my OEM rearsets which I would've liked back, but no chance of ever seeing them again I guess. _________________ Andy.
Andy wrote: the chassis disappeared along with my OEM rearsets which I would've liked back, but no chance of ever seeing them again I guess.
Tom had his chassis back along with all the other parts.
I sold my bodywork on and Tom had the forks off me _________________ Harley Davidson is the worlds most efficient way to turn petrol into noise without the harmful side effect of horsepower.
To be clear:
I have TSR rearsets, but I'd like some simple jack up plates to use the o.e footrests. I have to use plates to get around the JHA exhaust.
The JHA kit contains some spacers that perform the same function as a plate, but I'd prefer to have a plate, and get the footrest as low as possible around the exhaust. I guess a template and a chat with a metalworker is the best option. _________________
