6000 RPM
MC 21 BRIAN
6000 RPM
Wed Feb 10, 2010 7:08 pm » Post: #1 » Download Post
Hi, had the main bearings replaced on the 21 and the carbs sonic cleaned. Checked the jets were all the right size etc. Now its all back together and the guy at the shop took it for a run and it goes alright upto 6000 rpm then hits a brick wall. powervalves seem to be working properly.
Any ideas !!!!!! Sad
pbekkerh
Wed Feb 10, 2010 7:28 pm » Post: #2 » Download Post
Battery fully charged ?
generator charging ?
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
Wed Feb 10, 2010 10:13 pm » Post: #3 » Download Post
Powervalves cables fitted correctly and not backwards - so it closes at high revs instead of opens?
MC 21 BRIAN
Wed Feb 10, 2010 11:27 pm » Post: #4 » Download Post
Thanks for the replys, will pass them on to the maniac, any other possibilities appreciated.
Heres hoping. Exclamation
Thu Feb 11, 2010 6:47 am » Post: #5 » Download Post
MC 21 BRIAN wrote:will pass them on to the maniac
I wonder if that's what he actually meant to write? Shocked
Max szeged
Thu Feb 11, 2010 6:46 pm » Post: #6 » Download Post
Haha just a guess but maybe your bike is fine and he just loves riding it and dont want to give it back to you. Very Happy
feel the wind
bushman
Thu Feb 11, 2010 8:13 pm » Post: #7 » Download Post
Were the float heights set?
MC 21 BRIAN
Thu Feb 11, 2010 9:59 pm » Post: #8 » Download Post
Hi, that was my attempt at humour Laughing . Yes float heights set. Mentioned in conversation with the MECHANIC that when i got the bike it had no air filter in it, low and behold when i spoke to him today he says he ran it without the filter and it was much better, so can anyone give me jet sizes needle positions for standard settings in our lovely climate. Confused want to do the wire splice once i,ve had it running properly standard Laughing . Cant wait to get it back...
Sat Feb 13, 2010 10:01 am » Post: #9 » Download Post
Nope!
You'll have to jet it yourself according to your setup - is the bike completely stock? Any wire splice done? Airbox modified? Standard exhaust? HRC jet kit fitted?
Standard settings are for completely standard engines (obviously) and unless you know for absolute certain you're running a totally stock engine the only safe way to jet is by coming down the sizes until the plugs are looking right.
What jets are in it now?
What plugs?
Injector or pre-mix?
Any other mods?
MC 21 BRIAN
Sat Feb 13, 2010 4:38 pm » Post: #10 » Download Post
All standard, ngk br9 ecm plugs, standard jets as per the workshop section, standard airbox and filter, stock pipes and still using the oil pump. Looks like its definately down to the jetting Very Happy
Sat Feb 13, 2010 6:31 pm » Post: #11 » Download Post
Ah ok, what's it running now?
MC 21 BRIAN
Sun Feb 14, 2010 5:31 pm » Post: #12 » Download Post
When i last spoke to the mechanic he said he would have a fiddle with the needles and it was running a bit rough down the rev range. Will be speaking to him tomorrow so will post any news then.
thanks Dave.
