The barrels also come with new power valves.
Through the emails , Honda made loads of options between A.B & C
This kit was spec'd for a MC21 7L
Previously the front head was unavailable but my supplier asked for it to be made and it arrived
The factory also confirmed that what I have got will do the bike with no problems, they have also eliminated the whole A.B.C routine and all barrels are now under one new part number and are stamped "A"
They also confirmed that the type B pistons that I had ordered the original set for would be OK to use too.
So, I priced up the kit I have in the UK at £1,480.75
If I get 5 confirmed sets, I will supply this for 165,000 Yen delivered 3 day express airmail, at today's exchange (pretty darn low) that's £1,222 to your door.
If I get 10 confirmed sets (I get 10% of postage) I will do each set at 159,000 yen delivered to your door about £1,175
These prices are for whole of Europe, USA, Asia & Oceania (SA , need to add 5K Yen)
To speed things along - make a "dib" under the pretence you are buying at a group 5 level.
Once 5 have confirmed i will then set a 5 day deadline for other to join in and boost to 10.
I will also supply a piston & ring set at cost for any confirmed order if needed - sorry i haven't priced yet but will be cheaper than you can get !!
That way your not waiting for ever to get your kit and it can only get cheaper !
MM!
PS. The exchange is the worst I have seen to date and hopefully can only recover !!! Past 4 days it has dropped 5 yen to the pound.
Resistance is futile!
