breather hose location
Phatmc28
Thu Oct 09, 2008 3:26 am » Post: #1 » Download Post
where does the hose that comes off the engine just above the reed block goto , its currently blocked on my mc21 and i got no idea where it goes
Thu Oct 09, 2008 3:46 am » Post: #2 » Download Post
It runs between the inlet manifold subs, under the carbs, down the back of the crankcase and exits on the left (flywheel) side just above the expansion chamber.
There should be a metal retainer "loop" bolted to the frame that holds the pipe just clear of the expansion chamber and the chain.
Kubira
Fri Mar 19, 2010 12:09 am » Post: #3 » Download Post
what is the function of the hose in question, whats it letting breath? Also i would like to know, Where is the gearbox oil breather/overflow located
Fri Mar 19, 2010 5:31 pm » Post: #4 » Download Post
It's part of the environmental control setup, designed to allow any crankcase overpressure to bleed off to atmosphere and reduce the 2 stroke pollution...*
*This is actually a lie.
Kubira
Fri Mar 19, 2010 8:31 pm » Post: #5 » Download Post
nice Smile
