GPS fault?
bushman
GPS fault?
Sun Mar 28, 2010 12:42 pm » Post: #1 » Download Post
The neutral light began malfunctioning,so on investigation it turned out that the bolt securing the GPS had gone missing,and the sensor had moved outwards.I refitted it and replaced the bolt.I now have some running problems,at low rpm.At higher rpms the motor runs fine.If I have refitted the GPS wrongly,would this cause the problem?Is there a correct way to fit the sensor?
