I tested compression last night on a cold engine (155 psi top and 140 psi front cylinders).  Will compression increase or decrease with a warm engine?  Is the difference in pressures significant?  What is recommended minimum pressure?
Also, the top cylinder spark plug wiggles more than it should.  Back it out 1/4 turn and the tip moves almost 1/8".  The front cylinder wigles a tight 1/16" and is more what i am used to.  This plug was also loose.  I assume it vibrated loose?  Did vibration cause the excess wear?  Is there something that can be done to fill the void like plumbers pipe dope or teflon tape?
Thanks again.
