**Some edits since I first posted**
Ok my harness is here from Japan (thank you MM) and installed. It came with the HRC box and a tach. The tach has 2 studs on it to mount to 'something'. My questions are:
1. What's the part number for the HRC instrument cluster? Do I just use the MC18 F3 one that shows up on Yahoo Japan from time to time? (this one) http://page21.auctions.yahoo.co.jp/jp/auction/j41902520 Also, if anyone has the race cluster without a tach and wants to part with it please let me know. Edit - I discovered my stock instrument cluster's tach is nearly identical to the one that came with the harness (used, and with a 11.5k redline). My original tach has a 12K redline and seems to work fine with the HRC harness. I'd just like to ditch the speedometer and Neutral/side stand/oil/turn signal/high beam lights. Why oh why are they molded together??????!
2. It appears there's no fuse block as part of this harness. Luckily my dad wasn't around when I put that together or he would still be having a fit. I was just curious why there isn't at least a main fuse.
Once installed I simply added my battery and kicked the bike over - seemed to run fine without all the road equipment. Yay! Thanks for any help/advice. Now I have 2 more HRC parts on the track bike!
Craig
