Does anybody know what the finish is on the calipers, the current finish is lifting in places and looks awful. I have stripped the calipers down ready but need to know what the finish is.
Is it paint, powdercoat or as nsr wayne said might be a possibility stove enamel.
Would be great if someone could confirm so I can get them finished.
Martyn,
It is a High Temp enamel, the same as used with engine paint.
Just make sure you use a High Temp primer before applying the paint. _________________ Mike
