What's the best way to remove the dry clutch on a 1991 SE model. I can't get the clutch tool (two steel rings welded to a handle) in there to hold the clutch hub.
Also, is there a good source to buy a clutch hub. Mine looks pretty beat up.
Thanks for the advice. The motor is still in the frame. I thought it would be easier to remove the clutch while in the frame. That way I don't have to hole the motor still on a bench.
Can you still order NSR parts through a Honda dealer in the states?
Whilst your bike is in gear, with a rag-wrapped stick through the rear wheel. _________________ MC21SP Plaything
