MC18 base gaskets
CircuitR
MC18 base gaskets
Fri May 28, 2010 7:53 am » Post: #1 » Download Post
Hi guys,
Looks like I might need a new base gasket for my MC16/18. Just discovered a water seep from the top cylinder.
I had a look at TYGA but it looks like they only have HRC gaskets and I'm not sure on the thickness I need.
Does anyone know where I can get one in the southern hemisphere?
Or can a MC21 gasket work?
Blair
nsrdownunder
1993 Honda nsr 250 mc21 sp
Fri May 28, 2010 8:53 am » Post: #2 » Download Post
The base gaskets are the same mc18-mc21 only the head gaskets are different stock ones here in aus http://www.****.com/index.php?option=com_virtuemart&page=shop.browse&category_id=43&Itemid=26&vmcchk=1&Itemid=26
Dexter
Fri May 28, 2010 11:19 am » Post: #3 » Download Post
OEM gaskets are 0.5mm. As nsrdownunder said, 18 and 21 share the same ones.
Fri May 28, 2010 3:40 pm » Post: #4 » Download Post
ALL stock NSR's use the same 0.5mm base gasket.
CircuitR
Sat May 29, 2010 3:43 am » Post: #5 » Download Post
Cheers guys, I'll re torque it down and check how it is and if it's still seeping, I'll replace.
