on the end of the swing arm is a pinch bolt. Untighten that pinch bolt. you will see a toothed type plate. Use a spaner type wrench (that you adjust your rear shock with), and turn that disk. It will either pull the tire back, or push it forward. Adjust as normal, and tighten down the pinch bolts.
As far as I know, it's identical to the VFR400 / RVF400 (NC30 and 35) so if you know someone with one of those, have a look at their manual. _________________ MC21SP Plaything
