I bought an MC 28 a month ago but it only came with the standard card, I'm looking for a spare,
Thanks _________________ 98 NSR 250 MC28 SP - TF Movistar colours
Standard except for Bossom Exhaust system
Unfortunately the cards are programmed to the PGM; "blank" cards do not exist in normal circulation and even if they did they'd be useless.
Moriwaki-man can get cards programmed to PGM's (as well as made into HRC cards if required), see his link in the supporting vendors section, I think you need to supply a card.
Bat Motorcycles used to be able to get the cards new if you supplied your PGM number, it's on the card and the PGM but they're now closed.
If you want an old card to get reprogammed either to normal or HRC spec I've got both an HRC card and a normal card, they're from a dead PGM...open to offers. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
In the past when i was gothering parts in order to rebuild my MC28 i called David Silver Spares or Lings... I can't remember which one... And as Fontyyy told you, you give your PGM number and they can order it for you...
Hi, I'm new here...wondering where can i find the PGM number that u guys have mentioned?
I looked at my card...did not see any numbers that resembles serial no. on it...
If i get the used card from u...where can i send it to be reprogrammed?
Thanks and Regards
Admin: Please do not post non-sales in Classifieds. Ask questions in Discussion only. Please also see the forum rules regarding posting with TXT SPK, or your posts will be deleted immediately.
