I have the chance for a Wiseco piston to go with one of your barrels, which could sort my summer.
However I honestly have no Idea what is in there. I'll check my paperwork from TYGA and see if I have the info or is there a easy way to identify the make. I only have the head off at the minute.
If the Wiseco piston goes with what I have i'll buy one off you please. What does the coating process involve though?
Thanks Mal _________________ if it had a tail - it would wag
The wiseco pistons come from Tyga and fit the 300 barrel as intended . If you have a barrel replated , you send you new piston with the barrel and you can specify a clearance
If you are fussy and racing . Or you use the clearance they advise you to use
