Glen
Not convinced that the graph posted above is any representation of actual testing I have performed trackside..
Personally speaking myself and my wife run racing and track day events at Lakeside.. Included is Minimoto, Minitard, Scooters, Postie Bikes, Buckets (Moriwaki's and the like) and Supermoto..
All the 2T bikes except the Scooters have had to modify their pipes and or airbox's to reduce the db output..
This next picture is a simple slip-on muffler that was made up for the sole purpose of reducing the db output.. This slip-on knocks anywhere between 5-8db's of the overall reading, certainly does not require a trailer to carry it around and most definately does not reduce the power by over a half..
This is a Minimoto one but I also run the exact same design on my Moriwaki, only difference is that the Mori one is wider in diametre..
There is a ball of coarse steel wool placed inside the slip-on which gets pressed upto the end of the original muffler..
Now from personal experience running all my bikes with and without the slip-on, there would only be a 1hp drop at maximum, this test has also been performed side by side with other bikes to guage if one out performed the other, which it didn't..
So back to my original post..
1. I have been told by someone that by restricting the exhaust system to control the noise output on a bike will in turn overheat the motor and destroy it.. Yes/no?? EDIT: Also from riding and testing I have not noticed any increase in temp on my gauge whilst riding.. I only ask this becuase some apparent guru says otherwise..
2.I have also been told by someone else that by creating more heat will help with the combustion of the air/fuel and in turn create more power.. Yes/no??
3.What about heat wrap.. Is it a bad idea to wrap a 2T exhaust in heat wrap??
4.Is it a really bad idea to run one of the custom slip-on's on an NSR??
All question's are in regard to NSR's..
Oh and 80XAR, I've got stock airbox's although I'm currently not running them on the NSR's and although I have stock pipes I'm getting TYGA pipes in the next few weeks.. _________________ Paranoia about failure will ensure nothing but failure to ever reach potential.
MC18 Race bike project..
MC21 Race bike..
Tue Jul 27, 2010 7:37 am |
Major_Tom
1994 Honda NSR250 MC28SE
quote: Originally posted by Glen: Then can't the jetting just be changed to suit??
I must have misunderstood.. What exactly does the 'power' part of the graph refer too??
I take it some may have heard about Nology leads and silver spark plugs.. Would folks also say that these would be bad news for the motor as they create more spark and in turn more heat?? But would it not come back to jetting to suit??
I think the main factor that affects cylinder temperatures IS the jetting, and as you will know, lean = hot, rich = cool as the excess fuel helps to remove heat from the combustion chamber. You can run different heat range plugs, but I don't think this makes the engine run any hotter or cooler, it just dictates the operating temperature of the plug itself. Too cold and it won't get to it's self cleaning temperature, too hot and it will melt and possibly cause pre-ignition.
Sound is pressure waves travelling through air, a mechanical vibration, and there is energy associated with it (Joules, J), and hence power (Joules/Second, W). So that's what the power part is referring to. A -3 dB drop in sound level corresponds to a halving of the intensity of the source.
I would have thought that a stronger spark could only be good, faster burn > bigger bang > more power!
Hopefully I have my facts straight here.
Tue Jul 27, 2010 12:21 pm |
Page 1 of 2
Goto page 1, 2 Next |
Forum Rules:
< Last
Thread | Next Thread
