The HRC emulsion tube is slightly longer than the stock Honda one so if you run the HRC adjustable needle without the HRC emulsion tube there is a danger if you use the top clip position the needle will jam in the main jet. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
