Anyway here she is, as always pictures make it look better than it is and it's seized, the chassis looks clean and straight, bodywork needs some attention but it's all there.
Anyway first bit of help I need, there is a White multi pin connector under the tank with six light green wires with different colour traces on them, coming from the same stand alone bit of loom and exiting near the white connector is another light green wire with a red trace. The loom section comes out of the gearbox sprocket cover area and terminates under the tank above the carbs.
Thanks in advance.
It's connected to nothing and there is nothing to connect it to, what's missing please? All the obvious electrical boxes are present and correct, coils, servo motor, PGM, reg/rect etc.
