RS250 NX5 Cylinder Heads
kukkos
Thu Dec 30, 2010 7:10 pm » Post: #1 » Download Post
Hi guys !Sorry for the weird question Embarassed
It's possible installed the nx5 Cylinder heads on MC28Sp barrel Question
There are difference Rolling Eyes
Thanks
Alessandro
Alessandro Cucco
via Brigate Partigiane 43c
54033 Carrara (MS) Italy
Thu Dec 30, 2010 8:29 pm » Post: #2 » Download Post
Short (and only) answer, no.
Search the forum for posts related to HRC RS250 parts and the NSR, and you will find that bolting RS parts on (when you can) is most definitely NOT the answer to usable, reliable, cost-efficient power.
Sat Jan 01, 2011 9:06 pm » Post: #3 » Download Post
Andy wrote:you will find that bolting RS parts on (when you can) is most definitely NOT the answer to usable, reliable, cost-efficient power.
We'll see...Wink
Neal
Sun Jan 02, 2011 7:46 am » Post: #4 » Download Post
It all depends on what you want from your bike and the maintenance you intend on doing .
Hermit
Sun Jan 02, 2011 8:49 am » Post: #5 » Download Post
But if you're the sort of fella who's doing it for the love of it, you might appreciate the work of a certain Thai based expert we all know and love:
http://www.youtube.com/watch?v=6fN_79QBiYg
Sun Jan 02, 2011 10:33 am » Post: #6 » Download Post
Happy to say that the engine ran very strong this morning at the local race track. I had the usual crowd of 2 stroke haters waiting for it to break but it didn't Smile
It's now fitted with different exhaust manifolds and modified RS pipes.
The biggest issue was chasing the jetting. As the morning warmed up so I kept having to change the brass and never really got to the perfect setting.
Having said that, it now makes an NF5 feel very lethargic and will likely pass the NX5 down the chute. But........unfortunately for 300 haters like Granty, it still has dollops of midrange, so will out grunt the NX everywhere. If he wasn't such a lazy git and paid attention to my text messages at 7am this morning he could have come up for a ride. Oh well, his loss. He still hasn't answered so more than likely still kipping.
As for running NX5 parts on an NSR, I think you're not gonna have much luck without easy access to a fully equipped machine shop.
For the record, I'm trying this set up on two types of bottom end.
first we have my old NSR300 bottom end which is basically a well modified NSR, including stock (albeit perfectly trued up) crank, and VHM heads at 14.2cc for pump fuel.
Then there's this fire breather, which is a '92 NF5 bottom end. I epoxied and cut the cases for flow. Pistons Wiseco. VHM heads at 13.5cc burning avgas 100LL, PWK 39's (maybe too big, must try smaller) and an adjustable CDI. Pipes, as I said, started life as RS250 NF5 but mow modified the headers a touch. Manifolds are similar to my special NSR250 manifolds, which Brother Stephen has shown to give more mojo on his brake, in that they're matched to the port shape.
It suffers a bit from vibration as the engine's solidly mounted, just as it is in the NF, but hey, what's a few vibes among friends.
Anyway, I'm now very happy with this project, and will finally be able to sort out the people I've been promising results to.
To be honest I'm not sure where to go next. I have a 3MA on the bench which is great now that I've sorted the carburation out, but I think it needs surgery.
Then there's my Honda LS125. I'm thinking reverse the cylinder, out the arse pipe, big carb and and and.......
Neal
Sun Jan 02, 2011 5:42 pm » Post: #7 » Download Post
wow thats proper !
Would be good to compare to steves f3 .
Mon Jan 03, 2011 3:17 am » Post: #8 » Download Post
I've had the pleasure if riding pretty much every type of NSR from stock MC16 upwards. Unfortunately not an F3 MC16 though. The best of the range, with just HRC parts bolted on is the MC21 F3. Lovely smooth engine, free revving and good performance.
This RS300 engine is pretty much spec for spec the same as an F3. RS and F3 cranks are very similar. The gearbox is the same as near as you can see. But the RS300 cheats in that the clutch and primary drive components are much lighter.
Would I put it up against Steve's F3? Of course. Never shy away from a challenge.......or Steve's F3 Exclamation
