I've just finished rebuilding and reinstalling the carbs from my fairly early MC 18. The shop manual kindly advises not to remove the throttle position sensor, however, in order to properly clean all the gunk off the carb bodies in an ultrasonic cleaner I removed it. I can find no reference in the shop manual on how to adjust the tps. Given the way the actual sensor is fitted to the mounting I can't see there's much/any adjustment available. If they are adjustable, how is done and what readings should show up on a voltmeter or ohmeter?
Ken
Eastern Ontario
