 Topic: Torque Spec's?
cgallant
cgallant » Fri May 12, 2006 4:06 pm
Being a 6 mm bolt, it's normal torque setting is 0.8-1.2 kg-m.
For these bolts I generally don't use an actual torque setting and just expect it to be good.
I actually set the bolts while doing a leak down and make sure they are set so nothing leaks. This you will find is good to do if the intake boot is warped.
Charles Gallant
