I can't seem to find the torque spec for the intake boot bolts anywhere. Anyone know or can point me in the right direction? Thanks for the help. _________________ To much HP is barely adequate!
Being a 6 mm bolt, it's normal torque setting is 0.8-1.2 kg-m.
For these bolts I generally don't use an actual torque setting and just expect it to be good.
I actually set the bolts while doing a leak down and make sure they are set so nothing leaks. This you will find is good to do if the intake boot is warped. _________________ Charles Gallant
