I'm afraid it does sound like you've seized it.
First thing to do to pull the lower fairing off and remove the exhaust pipes. Have a good look up the exhaust port and see what kind of condition the pistons are in.
By the sounds of it, it might not be a full seize but might of whiped a ring which you can sometimes (if rarely) get away with by cleaning the barrel and fitting a new piston.
